Revolve Hole
Revolve Hole
a.winshel.hill
Revolve Hole
a.winshel.hill
Hello, I'm a beginner at Maya and have trouble whenever I revolve around my objects. For example, whenever I finish the outline using the Bezier Corner tool (viewpoint: Front), my model will have a dent at the bottom that looks like a hole. I've tried resetting the Revolve and Bezier Corner tools, but it didn't work. (I have also tried to change the Revolve Nurbs to Polygons - it didn't work either.) Strangely, if the bottom is flat, it forms a "dip hole," but a rounder surface doesn't show as much.
a.winshel.hill
Update: I assume the cause of the hole is because of the Bezier Corner outline I made, but how do you get rid of this weird hole?
damaggio
You need to merge all the vertices where the revolve surface meets.Keep in mind the surface should always be polygons.
