Reset scale to bounding box scale.
darioOrtisi
darioOrtisi
Hi guys.
I need an urgent help. I have a lot of objects and i need to reset the scale, that is to 1-1-1, to the bounding box dimensions.
So if i have a cube and scale it and freeze transformation, i get scale to 1-1-1. So i want that the scale reset to original based to BBox.
Anyone can helps me?
brentmc
The easiest way to do this is using a Mel script and you could tweak it to suit your needs.
For example, if you want the final scale to be uniform then you could use the min/max/average of the bounding box dimensions etc.
// For each selected object
for ($obj in `ls -sl`) {
    // Get the bounding box and calculate the scaling
    float $box[] = `xform -q -boundingBox $obj`;
    float $scl[] = { $box[3]-$box[0], $box[4]-$box[1], $box[5]-$box[2] };
    // Apply inverse scale
    xform -scale (1.0/$scl[0]) (1.0/$scl[1]) (1.0/$scl[2]) $obj;
    // Freeze scaling
    makeIdentity -apply 1 -scale 1 $obj;
    // Restore original scaling
    xform -scale $scl[0] $scl[1] $scl[2] $obj;
Brent McPherson
Principle Engineer
darioOrtisi
Hi @brentmc
It works, thank you very much. You saved me.
