replace object
replace object
Message 1 of 9
replace object
hi, i have a problem, i import object from zbrush, and now i want to replace it too another similar, so i press replace object and all object are overlapping each other.How can i fix this?
Replies (8)
Message 2 of 9
amaterasu-qbb
screenshot please.
Message 3 of 9
Message 5 of 9
hey what it means, pivots are set correct? on 0.0.0 in all object?
Message 6 of 9
mspeer
Hi!
In Local Space yes, but in World Space this depends on your object position.
Please provide the scene-file for further help.
Message 7 of 9
ok maybe you can help dont know what i do wrong
Message 8 of 9
mspeer
Hi!
1. Use "Bake Pivot" on "chain_high2:Group9288".
2. When you use Replace Objects you need to select all individual objects and not only the group, or only the group will be replaced as one single object.
3. Even if you do this then the new objects are not rotated, this is correct as the lowpoly objects don't have any rotation values set, so you need to correct this manual.
Message 9 of 9
i select all individual in group but dont use bake pivot, will try it, but whan i make replace in simple box, all work well in same scene
