Render distance
Render distance
Volt-Amper
Render distance
Volt-Amper
Good afternoon, how can I find out about the draw distance, I have a scene in which a subway tunnel is being built and I would like to slightly increase the draw distance. I found in Windows >> Settings/Preferences >> Preferences >> Cameras >> Far Clip the default value was 10000, tried to change to other values, added two zeros, but the range did not change. Tell me what setting is responsible for changing the distance from the camera to the object?
Volt-Amper
I entered the following command: setAttr "perspShape.farClipPlane" 100000
helped, now I'll increase it by a couple of zeros, but tell me where in the settings you can find this FarClipPlane value?
hamsterHamster
You can either invoke Create>Cameras>Camera[options] or, like you did in your command, open the camera's shape in AttributeEditor and change there.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
