Quick Question Regarding the UV Editor Window
I've been using Maya 2017 for almost a month now, and I just have a quick, and maybe simple, question regarding the UV Editor Window.
So the window itself gives you a graph which is normal.
I want to upload a texture that looks similar to figure 1, and in the program it gives it to me like figure 2. But I want it to look like figure 3,
where the each textures would take up one quadrant.
I guess the first question I should ask should be, is it possible?
If so, how would I go about doing this process?
Many thanks,
mspeer
Hi!
Do you really need this? Usually you want to keep coordinates within a 0 to 1 range.
1. In UV Editor: Image -> Image Range [options], set new range
2. Modify values of place2dTexture.
Thanks for the response!
I understand that one would usually want the coordinates within a 0-1 range. I guess you can say I'm just curious to see
whether or not its possible to have each texture take up one quadrant. Personally, that would make my work easier.
mspeer
Hi!
Did you get it to work?
Please mark every answer that solves your problem as solution, so others interested in this thread will get a better overview.
Oh, my bad! I'm still new to this whole forums thing. No, I still can't get it to work.
Doing what you originally told me to do would, of course, expand/shorten the given coordinates. Yet the texture would just repeat itself like the picture attached. (Of course, a 0-1 range would produce something like figure 2, and anything else would be kinda like what I just stated.).
  Perhaps I need to rephrase the question:
Say square A is 512x512 and its UVs fit perfectly into it(Using figure 1).
Using only square A in a texture file on one quadrant would perfectly give me the same 512x512 ratio, and no edits need to be made.
But then again, that is just for square A. I want to have all squares in the same texture file so that I wouldn't have 4 separate files in general.
Doing that would produce something like figure 2, and the aspect ratio is not 512x512 anymore on just one square. And personally, I want to avoid shortening my UVs along with it.
That's why I ask if there is a way to maintain the aspect ratio of 512x512 on all squares and using all 4 quadrants, like figure 3.
mspeer
Hi!
Sure, and i gave you the solution.
Again:
It seems you stopped after 1.
It appears I have, sorry!
After messing around with the values in the place2dTexture, I finally got what I wanted. Thank you so much for your help! 🙂
