Project Curve onto NURBS Surface
greech82
greech82
This must be an easy question, but I can't find the solution:
I extruded a NURBS circle to make a vertical trunk of a cactus.
Now I am adding branches to the cactus -
On the left, I was able to successfully project a new nurbs circle on the vertical trunk and attach a cactus limb.
On the right, however, whenever I project that nurbs circle seen, it breaks into two pieces and also adds a horizontal circle around the vertical trunk. It does not successfully loft to add a new limb.
Why is it working on the left and not on the right?
greech82
Also, let me note that on the left side, despite the curve projecting over the section line, it does not break up the circle.
