Problem with Revolve Tool
sukhraj_aulakh
sukhraj_aulakh
So I was trying to follow a tutorial for a college Maya assignment and I had to use the revolve tool on this shape: Screenshot 2024-10-29 001459.png
The tutorial that I was following was able to get this shape by clicking the revolve tool:Screenshot 2024-10-29 001527.png
But, when I tried it myself I got this shape:Screenshot 2024-10-29 001514.png
How can I solve this problem?
muneto
First of all, check the axis to be revolve. In this case, the axis to be revolve is the X axis.
Open the revolve options box, change the Axis preset to X, and click the Revolve button.
That will create the desired shape.
Or, after executing the command, click on “revolve*” (* is a number) in INPUTS in the Channelbox and enter 1 for AxisX, Y, or Z.
sukhraj_aulakh
How can I get the hole for the wheel?
muneto
Has Revolve been completed?
The holes for the wheels are another question.
If you are making it in NURBS, you can make the holes by stacking the cylinders for the holes and Boolean.
https://help.autodesk.com/view/MAYAUL/2025/ENU/?guid=GUID-8F4663A0-BD9C-46E5-BB04-21C98F1F0EF4
After that, you can create a beveled edge by executing Round.
https://help.autodesk.com/view/MAYAUL/2025/ENU/?guid=GUID-66B628EE-3E6C-482F-87F1-56C0AB881F28
If it is a polygon object, you can also create a hole by stacking cylinders for the hole and booleaning. I think it would be better if the edges were handled cleanly before executing the bevel.
https://www.youtube.com/watch?v=aQn2f1Z3Tp4
