Problem with multi-cut tool
Hi there
I have a problem with the multi-cut tool. Sometimes it will only work properly or snap on other edges of the object as shown in the screencast.
How to fix this?
Hmm I dont know I couldnt attach a screencast the forum came with this error:
"Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied."
I recoded the issue with my phone, and attached it
brentmc
We would probably need the model (or part of the model that shows the issue) to properly investigate this.
Thanks.
Brent
Brent McPherson
Principle Engineer
Ok I think I found out what's problem:
When I opened the model on my computer at my office, there's no problem.
So It must be something with the configuration of the Maya version I have installed at my home office, since the version I have at my office is a nearly fresh install
brentmc
Sometimes issues like this are also related to your graphics card driver so wouldn't hurt to check the driver version on your home computer against the Maya certified driver version for you card.
https://knowledge.autodesk.com/support/maya/learn-explore/caas/simplecontent/content/maya-certified-...
Brent
Brent McPherson
Principle Engineer
