Announcements
Problem with edge loops
ahmedm.mamoun
ahmedm.mamoun
Today i get a problem when i try to model a blade and that happened when i insert edge loops to a cylinder then apply editmesh -> chamfer modifier it's okey and i get the shape that i want and after that i tried to merge the points to make the point that come from edge loops and chemfer one and when i try to extrude i get the problem that attached in the image  " edge loops appear and devide the object from diamond shape to a trinagle shape
video for what i am done : https://youtu.be/Y9aJMLEJ2zs
thanks
damaggio
chamfer.jpgYou just offset way too much for the scale of your object. try a smaller value and enable heads up display to make sure vertices get merged.Also a good practice is to model in real world scale and use .ma file, not mb.
ahmedm.mamoun
Hello ,
Thanks for your reply
but the offset i made was .12 and it's too small and i tried it again
and the same happened unfortunately
ahmedm.mamoun
Hello Mr Rodolfo
After a few tries i know where the problem is i was try to extrude the object in obj mode but when i change it to extrude face it's works
Thanks so much
damaggio
That’s great, yes use the pop up window settings first , although in some cases extruding with the handle can also give the desired result.
