Possible to rotate specific CV's of a sweep mesh curve?
justin5PV6Q
justin5PV6Q
I know there is a "rotate" function for a sweep mesh, but that rotate the entire length of the mesh.  Also there is a taper curve but no rotate curve....
You can't just grab a CV and rotate it either.
I'd like to be able to control how the sweep curve rotates along the curve with more precision.
Any suggestions?
Christoph_Schaedl
Mayas points does not have a rotaion.
https://linktr.ee/cg_oglu
The-Digital-Shaman
Really?
What would explain offset of rotation of objects attached to a path, in an axis which causes them to revolve around the spline?
