poly modeling error
poly modeling error
sreeniketh
poly modeling error
sreeniketh
can't find polygons in poly modeling
hamsterHamster
Your image doesn't show the rightmost edge of the shelf.. you'll probably see there something like this:
.. and then you might guess what to do.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
sreeniketh
hamsterHamster
Hah, strange. Are other shelves empty too?
At the leftmost part of shelf panel there's a small square which, if clicked, will give you access to the ShelfEditor (same Windows>Settings/Prefs>ShelfEditor) - see if there the PolyModelling panel is really empty. If so, then the settings seem to be corrupted. If nothing fancy about your hotkeys, plugins and layout settings, then easiest would be to reset settings completely by exiting Maya, deleting entire C:\Users\User\Documents\maya\20XX\prefs folder, re-launching Maya - the default profile with all icons will be recreated. Otherwise, you can add your own (frequently used and customized) icons to the shelf by ctrl+shift+LMB-clicking any top menu item.
,,,_°(O__O)°_,,,
sreeniketh
thank you, i finally got it 🙂
