paint soften edges
paint soften edges
HeavyMetalFox
Message 1 of 9
paint soften edges
HeavyMetalFox
Is there a way to paint edges so they are hard or soft instead of having to select each edge and apply soften or harden
I remember there is a marking menu for this, am I right?
Replies (8)
Message 2 of 9
artfully3d
Hi!
If you Shift+RightClick on your edge, there will be a marking menu for Soften/Hard edges
Message 3 of 9
HeavyMetalFox
Yes, I know this tool, but its not a "paint" tool?
Message 4 of 9
brentmc
You can use the Paint Selection Tool to select the edges and then run soften edges on the selection.
Brent McPherson
Principle Software Developer
Message 5 of 9
HeavyMetalFox
Isn't there a way to paint to "soften edge" action?
Message 6 of 9
brentmc
The brushes in Maya can be scripted so it is possible to make a custom soften (or harden) edges brush.
Here is a script that will do the job and I just copied the shaderPaintTool.mel example in the installed Maya scripts and adapted it to soften edges.
Save this to a file called edgeSoftenPaintTool.mel in your script path. (or paste everything except the first line into the script editor and run it)
Note: The magic sauce is the -bsc/-beforeStrokeCmd and -asc/-afterStrokeCmd flags where you can define commands that get run before and after every brush stroke.
global proc edgeSoftenPaintTool()
	global string $gEdgeSoftenPaintTool;
	if ($gEdgeSoftenPaintTool == "") {
		$gEdgeSoftenPaintTool = `eval "artSelectCtx -i1 \"artSelect.png\" -ads false edgeSoftenPaintContext"`;
    string	$cmd;
	$cmd  = "ArtPaintSelectTool; artSelectCtx -e";
	$cmd += " -bsc \"setComponentPickMask Edge true;\"";
	$cmd += " -asc \"polySoftEdge -a 180 -ch 1;";
	$cmd += "select -clear;\" ";
	$cmd +=	$gEdgeSoftenPaintTool;
	eval $cmd;
	setToolTo $gEdgeSoftenPaintTool;
Brent McPherson
Message 7 of 9
HeavyMetalFox
Thanks alot man, works like a charm 🙂
When I paint it on edges, it  highlights them before applying the soften which is a bit distracting and not very smooth (even id "reselecting highlights" is turned off in thea2.jpg select menu)
Is there a way to paint directly without highlights things?
Message 8 of 9
brentmc
No, it is not possible to avoid selecting the edges while painting because the script uses the paint select tool and it softens the edges after each stroke. (and clears the selection)
Brent McPherson
Message 9 of 9
HeavyMetalFox
ok thanks alot.
