OpenCL Error: Out of device memory. OpenCL Error: Out of resources.
every time I'm modeling and I'm going to insert another vertex or press the 3 key, the modeled object disappears ... and this message appears: OpenCL Error: Out of device memory.
OpenCL Error: Out of resources. DO YOU KNOW HOW TO TELL ME WHY HAPPENING? and the machine here has the requirements and the memory is all ok, I need someone to do a remote session, access my computer to see what is happening, because I am not able to study with Maya showing flaws.
mspeer
Hi!
This is usually a GPU/driver problem.
(Please make sure to use a proper 3D graphic card with Maya.)
What you can try:
1. Update you graphic card driver
2. Add
MAYA_DISABLE_OPENCL=1
to your Maya.env file.
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Maya-Env...
