Objects disappear after boolean operation?
Message 1 of 11
Hi,when aplying mesh->boolean->difference both objects disappear?
http://youtu.be/YojjupuHXSk
Any ideas how to solve this?Thanks
Replies (10)
Message 2 of 11
n8skow
Tried deleting history on both objects before boolean?
Try moving one of the objects very slightly - and then boolean...
Sometimes if the geometry lines up strangely it can do this - or perhaps your geometry is just too complicated to boolean...
Message 3 of 11
history deleted.object moved same behaviour.my geometry is a revolvedsurfaceshape.
Message 4 of 11
the issue was on the extrude options Curve Settings-->curve-->select none and after this the boolean works fine.solved,thanks for your time.
Message 5 of 11
Hi Everyone.
This does not seem to be solved. I am able to boolean my object in Max but do the same process in Maya and the objects disapear. All my nodes are clean and the transforms are zeroed out. I feel like this is a major issue. Sometimes the workflow of a complicated object does not allow for transfering from Max to Maya, so it would be nice if this feature was more stable. Seeing how this thread is a few years old I am surprised that this feture still behaves like this. At this point it will take me close to 500% more hours to model the cross cut in my model without this operation. All I ask is to get similar results accross your software packages.
Thank you.
-Ben
Message 6 of 11
Anifex09
What version of Maya are you using. The boolean operation has been updated in maya 2015. It works much better than before but still a little slow in comparison to Max. When working with animated booleans to cut objects I find myself creating animated cache geo files to ensure a clean result when rendering.
Message 7 of 11
Hi, that was on maya 2013
Message 8 of 11
anna.bernal
I still have the same issue, 2020.
The objects are two simple cylinders, yet any boolean operation with them makes both objects dissappear, I did try cleaning the history.
Message 9 of 11
Hi, that was a long time ago i cant remember well the solution,i think it was a bad procedure,the way i was using the tool...
Message 10 of 11
anna.bernal
thanks anyway!
Message 11 of 11
damaggio
There are different types of Boolean operations.
