obj file does not show anything
I am really new to Maya and I want to create a model of chess piece (pawn) with it. I followed this video https://www.youtube.com/watch?v=wt4oMqSL0iE on youtube, but when I export the selection with obj format (format that I need) there is nothing in the file except for a line "
# This file uses centimeters as units for non-parametric coordinates.
mtllib pawn_3.mtl
". And of course nothing happens when I try to reimport that obj file back into maya.
My guess is that the export setting has something wrong, but I am not sure where it is. Could you provide some potential fix that I can try out? Any feedback is appreciated. Also .obj is the format I need.
Attached is a snap shot of the settings and the plugin manager.
I feel like this is not an issue of the way of building the models; guess I will still try other tutorials.
Thanks!
_sebastian_f
the tutorial seems to use nurbs as output for the revolve. if you did that to you need to convert your model to polygons first (modify > convert > nurbs to polygons) before you can export as obj since this format can only store polygon data.
