need mesh triangle to be on same direction
i need the triangles of my mesh to be on same direction. As triangulating it from quads making the triangle to on random direction. plz need help on it
mspeer
Hi!
You can select and rotate edges with
Edit Mesh -> Spin...
stuzzz
this will be a tedious job considering the amount of triangles to process.
mspeer
Hi!
1. This should not take too much time, if you use a selection constraint less than one minute.
2. It's also possible to correct only some edges and then rebuild the model with duplicate + merge.
