need help plz !!
need help plz !!
need help plz !!
i was working on maya 2014 everything was perfect and then i wanted to make a normal polygon .. i can't find INPUT in the channel box so i can add subdivisions .. i know i can add subdivions from another area but why its not there ? .. i maybe used to click on shapes on channel box and all the subdivions used to come right away but now no 😞
another thing am sorry .. when i want to extrude a face or egde or whatever i don't actually see the tool after i click it .. no x,y or z axis to manipulate them .. the tool work but its just invisible how is that .. i made sure by the move tool after making some extrusion and it works but with blind manipulation in my case ,, why does maya acting so weird 😞
NOTE : i delete the software then install it again .. same issue exist
and i tried to restore defualt setting many times ..
pshwayka
For problem 1 - You have your construction history turned off.  Click on the icon at the top of your screen shown below to turn it back on.
For problem 2, click on the "Show" menu just above the viewport and make sure "Manipulators" is checked.
man if anything i can do to thank u enough tell me 😄
you saved my life my respected master .. thanks a lot .. best luck for u 🙂
pshwayka
Happy to help.  Smiley Happy
