Announcements
nCloth
nCloth
nCloth
*summons Mspeer and Roland from the void*
Hi again 🙂
So I have a new thing. Now that my boots have such wonderful laces, they need creases and wrinkles. I could just model them, but where would be the fun in that? And besides, the point of this whole thing is to learn new stuff. So I am mucking around with nCloth. mb  pic can save a few thousand words.
The one on the left is the nCloth. The right is a duplicate that I gave a go of the smooth brush from the sculpting tools.
So this has not been a total failure 🙂 I haven't gotten exactly the desired result yet, but I am making progress. What I am trying atm, is to
hang the sleeve of the boot from a passive collider, using a dynamic constraint,
run another leg-shaped passive collider through the middle
apply a horizontal wrinkle map
change the gravity in the neucleus to  .5
increase the collision and self collision thickness of the nCloth
I have tried a few of the ncloth presets. This one is using the silk preset. So far it seems to have had the best results.
So, is there a pro-tip for all this? Some stroke of inspired genius to make this a viable technique? Even a slightly depressing "nice try but this will never work". please? be your BFF.
ty.
mspeer
Hi!
The easiest solution would be to use sculpting (and painting of bump maps for smaller details). If you want a simulation you need to paint maps for different values of your nCloth object (to simulate variations in material properties), so it seems you are on the right way.
hi.
I did actually just sculpt the folds that I wanted. I had to move on. But I haven't given up on the simulation thing 🙂 ncloth is very cool stuff. I have learnt all sorts of things I didn't know you could do. The turning point was when I found out about scale. I suppose you knew that ncloth works in meters. I didn't know this. Once you adjust for that things begin to work in a much more expected fashion. So Vx.x of my character will have simulated stuff, but I am afraid my tutor will have to miss out on the fun.
thx for stopping by. Have a good day.
