My Movie is not showing in image plane
Message 1 of 11
Images show movies don't why is that, this worked in school not home  i have maya update 4 so it should work  i linked my files it says the mov is not a supported file type, like it says in the images i screen shot. I really need this so i can work from home for assignment  please help guys this needs to be fixed quickly!!!
And it didn't work with mp4 either this doesn't make  sense it worked in school with same file type please please someone get back to me asap  this is kind of an emergency time
thanks
Nikunj
Replies (10)
Message 2 of 11
mspeer
Hi!
The message says "file type or codec" doesn't work.
Do you have the same system (OS + installed software packages) as in school?
Does it work at school with a file with same file extension or with the exact same file?
Message 3 of 11
  • Hey man no but i really don't think it should be much of a problem(i maybe wrong)
  • i have windows 10 they have windows 7 i have maya update 4 they have maya update 3, with uvs no problem, image planes no problem shows up
  • viewport 2.0 works fine for both to my believe haven't seen any trouble other than relinking the files one by one as set project doesn't do the job of getting the linked textures back.
  • In School i have different file extension but even if i have different  extension the rest i can link one by 1  the video i can't  haven't tried in school but i'm really sure it would probably link back ok in school but home i get any video file i even tried an mp4 one(not a one related to assingment for a test run even that did not link)
  • The exact video links fine in school
  • But the video won't link so not sure at this point but idk  if the other things can link to an extent, the video should too,   i'm so confused man 😞
Sorry man if there is any part of this you don't get or if i didn't answer your question ask many times as possible  but really wish i get a solution
Message 4 of 11
mspeer
Hi!
1. Maya has very limited "movie / codec" capabilities and relies on formats supported by OS/system.
2. Win 10 or Win 7 is a big difference and could be responsible for your problem.
3. I'm a bit confused you say
a) "In School i have different file extension", and
b) "The exact video links fine in school"
The best option, also to keep a project compatible to other systems, is to use an Image Sequence.
I'm sorry i can't help you further with this.
Message 5 of 11
No Man  i tried in my other computer too that uses windows 8.1 i even had downloaded videos in windows 8.1 and it still did not load the files i think the question then is could you please link me to the codecs maya supports please so i can download them cause this issue is really getting on my nerves and draining me down
Message 6 of 11
i am also experiencing the same problem and i have tried files with different fie extensions aswell but the movie clip is not showing up in my maya software
Message 7 of 11
I'm having that same problem now did you find the solution for it... Please help me
Message 8 of 11
roshanshilimkar3434
For further viewers I know this is an old thread ,Hello, the problem here is you trying to use .mov file which is not supported, in this case please convert your .mov to .avi or jpeg/png sequence and try .Also mp4 is not supported so what you tried gave you the same error.
I've attached a sample avi file for you to test that avi plays in maya just download that avi and try instead of current footage, if it works then convert your footage from .mov to .avi with software like premiere or online conversion websites like- https://convertio.co/convert-mov-to-avi/
which will keep the frame rate same as before but will change the extension
Supported Maya image/video files: psd, als, avi, dds, gif, jpg, cin, iff, exr, png, eps, yuv, pic, hdr, sgi, tim, tga, tif, rla, bmp, xpm. (Source: Autodesk Knowledge Network) this formats are only supported in maya
Accept as a solution if this helps,
Message 9 of 11
cavescholar
I use Windows and school computers are Macs.
I have fixed a similar problem before by installing iTunes or Quicktime for Windows, which is not standard for Windows.
Once you install it you will have the codec for MOV files.
Since Quicktime I believe was replaced by iTunes, installing iTunes may fix it if Quicktime doesn't
NOTE: These are not Maya products and are from Apple.
Go to your Microsoft Store app, search for iTunes to find it.
I would make sure save your work and have Maya closed before you install.
After you install restart, then test to see if it worked,
Good Luck!
Message 10 of 11
denizserragoksu
Observer
Observer
Hello, I have been having the same problem with every movie file. I have tried .avi but it never works. (even tried .mov and .mp4) I have the last update. Converting it to image files works but it is too much of a hassle and my workflow really slows down. It doesn't give me any errors or anything. I have tried every option but nothing works. What is the reason for this.
Message 11 of 11
baryafe
same i have the latest 2025... use avi and still see nothing
