Multicut tool joining cuts
omar.shello
Message 1 of 9
omar.shello
I'm facing an issue for the first time, the multicut tool is joining the cuts when my symmetry is on, i tried and reinstalled maya but still didnt work
Replies (8)
Message 2 of 9
mspeer
Hi!
This does not work.
You need a border edge at the center for symmetry in this case.
Without symmetry you can also use Insert Edge Loop tool with "Multiple edge loops" enabled.
Message 3 of 9
omar.shello
hello there, thanks for replying
i know putting an edge in the middle would help but it wont fix the main issue, because im used to do it without putting middle edges, i have the same problem even with cubes like in this video. its a bug that appeared in maya 2018 as far as i remember, got fixed but i dont know why its doing it again in maya 2020.
https://www.youtube.com/watch?v=MfH8tBgNMEI
Message 4 of 9
mspeer
Hi!
I don't know any Maya version where this works different.
Message 5 of 9
omar.shello
Hello there hope you are doing well.
I contacted the support team and hope they find a solution. None the less thank you for the help I really appreciate it.
Message 6 of 9
al361691
Hello, could you please share this solution? 😞
Thanks.
Message 7 of 9
omar.shello
Hey there,
I asked on discord long time ago and i was told it should have an edge in the middle to work tho i used to do it without an edge before that
Message 8 of 9
al361691
It works! :D. I swear I had tried before but maybe I'm wrong, now works
fine thank you.
Álvaro
Message 9 of 9
hamsterHamster
The thing is that multi-cut tool works fine when each edge it affects is divided just once. Therefore the middle edge is a must for the symmetry option.
I doubt it ever worked otherwise, even in the early Maya versions.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
