Announcements
Multi-Cut tool doesn't go all the way through geometry
maeyoshi
maeyoshi
I'm having trouble with Multi-Cut tool, but I think it has to do with my geometry.
I'm trying to insert an edge loop on a surface using Multi-Cut tool, but the edge cuts off in the center of the geometry.
I checked the center part, but there doesn't seem to be double vertex, edges, or faces around it.
But when I see the geometry in Vertex Face mode, there is a plane separating right and left parts of the geometry, and I think that's the reason why the Multi-Cut tool only works in either part of the geometry at a time.
I'm using Maya 2020.
I have attached my Maya file here.
I would really appreciate it if someone could solve this issue.
GeometryGeometryMulti-CutMulti-CutVertex Face modeVertex Face mode
hi, just delete that plane they should not be there and thats is
maeyoshi
I can't delete it.
mspeer
Hi!
Select this part only (some faces) and use Show -> Isolate Select -> View Selected
Then you can delete these faces inside (there are 2 faces on top of each other), then it works.
maeyoshi
Thank you!
Could you tell me which faces are overlapping?
I can't find them.
maeyoshi
Never mind, I figure that out!
I was able to delete the double faces inside and Multi-cut now works throughout the geometry!
Thank you so much!!
You are my savior!
maeyoshi
Thank you so much!
You are my savior!
