- Mute
- Permalink
- Report
I'm having trouble with Multi-Cut tool, but I think it has to do with my geometry.
I'm trying to insert an edge loop on a surface using Multi-Cut tool, but the edge cuts off in the center of the geometry.
I checked the center part, but there doesn't seem to be double vertex, edges, or faces around it.
But when I see the geometry in Vertex Face mode, there is a plane separating right and left parts of the geometry, and I think that's the reason why the Multi-Cut tool only works in either part of the geometry at a time.
I'm using Maya 2020.
I have attached my Maya file here.
I would really appreciate it if someone could solve this issue. Geometry
Multi-Cut
Vertex Face mode
