moving edge loop verticies independently
I have been trying to get help with this topic for quite some time. After inserting edge loops they won't move independently so that I can model my character. I have attached a screen shot. with my first project they were both moving right at the same time. And now, well see screen shot.
Thank you,
sean.heasley
Hi @Anonymous
It looks like you have soft selection enabled which is why the edge loops are yellow/red.
To disable this, simply press the B key!
Please let me know if this works or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided on Friday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
No, I haven’t gotten it to work. I need more suggestions.
sean.heasley
Hi @Anonymous
What's happening now? Are the vertices and edges still appearing yellow and red?
If they look that way you still have Soft Selection enabled which can be disabled by pressing the B key.
Once disable, the edges and vertices should appear light blue. Once they look like that you can grab and move them independently.
If this doesn't help, please post more screenshots or video of what's happening on your machine.
If you need a video capturing program, Screencast is a great option that we use here at Autodesk
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
