Move sub-objects (verts) numerically?
transistor06
transistor06
So, when in object mode, I can manually input numbers to translate, rotate, and scale an object - either in the channel box, or in the attribute editor.
But what about subobjects (components) like verts, faces, and edges?
Sure I can move em around with the manipulator, but where can I manually enter in precise numbers?
Thanks in advance 🙂
tdHendrix
You can select the components, in this case the vertices, and go to Window->General Editors->Component Editor. Then go to the Polygons tab and there'll you'll be able to enter numerical values.
Or you can type this command into the command line or script editor:
move -relative 0.4 0 0
That will take what's selected and move it over 0.4 units in X.
Greg Hendrix - Senior Technical Animator
LinkedIn : Twitter
transistor06
awesome!! thanks 🙂
