Modeling help
Modeling help
Message 1 of 1
Modeling help
Hi
I am a student.I was given this image to create in 3d but i have run into a few problems.
The Building pattern and the Screw like Helix pattern  on the cone shape.
So when i try to Extrude the shape on the curve its mangled i have tried few different ways to do it like extruding face instead of surface,
Different combination Of Extrude option But it Still turns out Mangled.
2nd Problem
When i try to create the building pattern how to i make it Spiral in the surface ? as you can see in the image it scales IN and DOWN as it goes up.
When i try to do it manually it Breaks the flow
Replies (0)
