Model turns green when exporting to stl
Hi, I'm pretty new to maya and am modeling to 3d print. My first model exported and printed fine, but I made another and now when I export selection the model turns green and in the stl 3d object file the object is a complete mess. the first model I used symmetry on a polygon and the second time I mirrored the other half.
dariush
That green shows up when the object has lost its connection to its material or shader (like Lambert1 for default). Just assign a new material to it and you should be fine.
My question is why is this happening and are there best practices to avoid it from happening? (I'm also new to posting to the forum so I don't know best practices for this either).
Okay I thought I tried that and it seemed to fix the green, but it is still a mess in the 3d viewer after exporting to STL file format.
So I was wrong, it still changes to green even after I've assigned a new material and still shows as a jumbled mess once exported.
So if I move the model out of place and the export it a green shadow model appears where it was. I have no idea what is going on...
dariush
This looks like you have multiples of the same object all in the same place. Take a look in the Outliner and see how many objects are there.
As far as it being a mess when you export an STL, that depends on the geometry and I'm not even sure where to begin debugging that.
