Mesh deforming when adding edge loop
Grizzly.B
Grizzly.B
Hi all,
My mesh keeps on deforming/being altered whenever I add an edge loop for some reason, regardless of the scene I'm working on. I've reset the tool, made brand new scenes, and even reinstalled Maya, but the issue is still there. I've attached some videos below to demonstrate the issue. Any help is appreciated 🙂
Michael
Cylinder example:
https://streamable.com/1mzqlq
Cube example:
https://streamable.com/n2dugm
mihirsbcc
If you go to the option box of the Insert Edge Loop, you will see Insert with edge flow on. Turn it off.
Grizzly.B
Thank you so much! You're a life saver man 🙂
