Merge Vertex Tool does not work with Close Proximity verts
Hi Autodesk Support
Iv recently installed maya 2018 and have been re-acquainting myself with the modelling process. I started a new model the other day and during which I attempted to apply the merge vertices function  to the model but was met with this error:
// Error: file: C:/Program Files/Autodesk/Maya2018/scripts/others/performPolyMerge.mel line 335: Found no items to list the history for.
I am used to using this function to merge overlapping or hidden vertex's within the proximity of each other, a method which has proved useful in quickly cleaning up the objects mesh. This problem is not isolated to this one project or scene, I have found that this problem has occurred in all my other instances that I have open a fresh maya window, but that process is very tedious and time consuming. I have tried deleting the maya folder in the documents folder in hope that the reset would resolve the problem, but have found no fix. I would greatly appreciate it if you would be able to provide any possible solutions to this problem.
Kind Regards Miles
Thankyou.
NVM figured it out didnt realize that you had to select all the verts for it to work
