Maya Texture is not showing in UV EdITOR
Hi guys!
                 i just created this sports bike 3d model. but when i click on the mesh i am not able to see the texture in UV EDITOR. i attached the image below. kindly help me out guys
Hi! According to your screenshot (and overlapped UV shells), I could guess you have multiple textures on the selected mesh. Try to click on the Texture menu in the UV editor and select the correct one. Also, I've seen the problem when the UV editor just displays the texture in the wrong square. Zoom out and check if it so.
And last: just be sure you assigned correct material with texture map on this mesh, maybe it's just a clean material.
