Maya can't merge two vertices?
I can't believe there is no option to merge two vertices to "first" or "last" position.
I can merge only to center, but what if i wont? Even in free analogs it's done better...
All what im trying to do is merge two vertices to last selected vertex position.
Is it even possible in maya? Thanks
Now im like retard moving 2nd vertex to 1st vertex position so it wont affect on geometry after merge 🙄
mcw0
No...not directly with the merge tool.  As you've stated, it merges to the center of the selected vertices.  The only solution is to snap your first vertex to your second.   And then merge.  You could write yourself a script to do that.
mspeer
Hi!
I guess you are just using the wrong tool. Use
Mesh Tools > Target Weld
this has the option you are searching for.
cavescholar
@mspeer yup, very cool tool! You just drag one vert/edge to the other and bingo!
mcw0
Never used that one.  Good to know.  Thanks
