Maya 2017 Slow Viewports
Message 1 of 18
Hey,
I have been modeling in Maya for about 2 months now. It worked perfect until two weeks ago. My viewports, and only my viewports are really slow. I can't seem to fix this.
Possible Solutions tried:
- Resetting the Prefs folder
- Changing viewport sizes
- Changing workspace (Maya Classic, Maya Modeling etc.)
- Changing viewport renderer (2.0, Legacy Default, Legacy High)
- Updating GPU Drivers
- Restarting PC (You never know)
- Deleting and refreshing Cache
_________________________________________________________________________________________
PC Specs:
GTX 760
8GB RAM
i5 3.10 GHz
Windows 10 Pro
Output Window: https://gyazo.com/bb1375ddaa2d12ff23ade512868dbb47
I hope someone can help me!
Greetings.
Replies (17)
Message 2 of 18
damaggio
Have you deleted your modeling history TG?
Message 3 of 18
No, i haven't tried this yet. Where can i find ''History TG''?
Message 4 of 18
damaggio
Top menu- edit> delete history or delete all by type .
It's important to read how history works in the Maya docs and and when to choose the right delete history option.
Message 5 of 18
Didn't work, still the same. I also tried to set a new project. Still slow 😕
Do you have any other suggestions which i can try?
In the bottom bar this appears. Don't know if it has anything to do with my problem: https://gyazo.com/1afffcc668fb34397fa02252d6b6bf53
EDIT: Solving Error in bottom bar doesn't solve slow viewports
Message 6 of 18
damaggio
Hi Thynix, if your scene is quite simple and you are still experiencing lag , that could be your hardware configuration.
Also close everything when working in Maya...even internet.
My only suggestion you are not going to like it....upgrade your system...more ram and a better card.
Message 7 of 18
It just can't be my hardware. I had been working with Maya for 2 months without ANY problems. It worked PERFECT. I restarted my PC (which closes everything) I tried shutting down my internet. Still laggy. I must have clicked something somehow which lead to the slow viewports i have now.
Message 8 of 18
damaggio
well, there's only a few things that can slow down Maya if it was working fine at the begging , a major one is History and what is in the actual scene at this point in time.
As scenes grow in complexity everything else starts to slow down.
If you have deleted the prefs and started fresh on a new scene, do you still have an annoying lag?
Message 9 of 18
Yes. That is what makes this so weird.
I removed the prefs folder. Set a new project and create a default workspace.
I add a polygon and move it around.
Everything i do with the polygon is laggy (rotating, moving, moving vertexes etc.)
Message 10 of 18
damaggio
Have you updated Maya 2017 to SP2?
Message 11 of 18
I can't find the Service Pack 2 for Maya 2017. Do you have a link so i can try tomorrow?
Message 12 of 18
damaggio
Hi thynix, you should find the update in your Autodesk account page or checking thru the Application manager in your desktop.
Message 13 of 18
Updating Maya didn't work. I even did a repair and also a clean install. Unfortunately no succes. I guess i should try upgrading my PC 😕
Thanks for your help and i'll let you know if it worked if thats okey 🙂
Greetings,
Thynix
Message 14 of 18
hello
try disable MASH.dll in windows > settings/preferences > plugins > mash.dll (UNCHECK CHECKBOX TO TURN MASH OFF)
Message 15 of 18
Thanks for that responds. I recently build a new PC and all my problems are gone. Guess it was a lack of RAM. I accepted a solution.
Message 16 of 18
amitabhbarretto
Community Visitor
Community Visitor
Was suffering with the same problem, on Maya 2018 (mac os sierra)
Delete my Cache files; All works fine, even the lagging of hotkeys no more - ha
Solution - On Mac
Finder - Go (press option key) - Library - Caches (delete this folder)
I keep doing this every time I launch maya, hope it helps 😉
Message 17 of 18
You mean all caches??
Solution - On Mac
Message 18 of 18
Thank you infinitely,  I tried without any succes the ALL solutions proposed before your post,
and  UNCHECKING mash.dll Works for me !
Smiley Very Happy
