Maya 2015 vertex/face help!!
Message 1 of 14
How can I move three vertex lines for the Y position without the 3 lines moving at the same time example want to make a bubble out of the ground , I could not explain much hope you understand , I need help !!
sorry for not being able to explain much, anyway , I'm trying to do these bubbles . 🙂
Replies (13)
Message 2 of 14
J450NP13
Your question is kind of vague....
Shift select the ones you want to move?
Message 3 of 14
keith112
Okay so select your 3 vertices and then hit W to go into the move tool. Then click the Y manipulator once on the move tool, this will lock your movement to the Y position. You can also then just middle mouse drag to change the position as it's locked to the Y Axis.
Another solution is to go to the channel box by pressing CTRL+A or it should already be located on the right hand side. Then select, by clicking once, on the channel you want to move, for your example the y Position. Then hit CTRL and middle mouse click. You can also just input an amount you want to move.
Also when you say vertex lines you're kind of not making sense. Do you mean edges or vertices points? Hope this helps.
Message 4 of 14
I am Brazilian I did not explain quite the English kkkk ,
ultimately , I am willing to do these bubbles . ( if I wrote something wrong sorry )
Message 5 of 14
I'm Wanting Doing these Bubbles
Message 6 of 14
keith112
Try turning on soft select by pressing B. Or double click your move tool and turn on soft select in the options
Message 7 of 14
yes , I've tried for this form , however selecting the same vertex and trying to move , moves the whole object.
Message 8 of 14
Message 9 of 14
keith112
okay so
1) Make sure you're in component mode
2) Make sure you're only moving the vertices you want. The ones you want to move should be highlighted/coloured.
2) Your brush size when you turn on might be to big. To change this hold down B and left mouse drag. You'll notice a red circle get bigger and smaller
Message 10 of 14
how can I connect the component mode?
Message 11 of 14
keith112
You can change between object and component mode by pressing F8
Message 12 of 14
THANK YOU , so one more thing , how caught the brush?
Message 13 of 14
keith112
hmmm not really sure what you mean by "Caught the brush"
If you mean how do you select it, then hit W to go to the move tool and then press B to toggle soft select ON/OFF.
Message 14 of 14
kkkkk , thank you for helping me , problem solved , thanks 😄
