makeText tool - history does´nt work
I´ve tried to create a text with history on (Maya 2013 or Maya 2014), the history does´nt work - I could not change the Text or Font after Creation. If I remember earlier versions - it worked ... , mmhh
Has somebody an answer?
Thanks in advance
le horge
Karen.Snow
Hello Horge,
When you are creating Text, what type are you using?
History is available on the Bevel Type as there is a textForBevel node in the history. I do not believe there was ever a history node on the other types as they are a single command.
Let me know if you have any further questions regarding this.
Cheers,
Karen
Karen Snow
Ha! It was the first time in 20 years 3D that I´ve used the text-tool only for generating splines AND need a solution to change font and characters via history -  and I did´nt know that it workes only for bevel - butb anyway, it helps me!
Thanks!
