Announcements
Make loop cuts with the multi cut tool
VansFannel
VansFannel
Hi!
I'm watching a course and the teacher does this with the multi cut tool:
But I can't do it.
He does all of these cuts with the multi cut tool:
How can I do it?
Thanks!
damaggio
Hold with Shift
VansFannel
It appears if I hold Control with LMB.
But, when I tried the first time, it doesn't work. Sometimes, something strange happens with Maya: at first, it doesn't work, but later on, it works.
By the way, the teacher doesn't hold any key to use it.
damaggio
I rarely use that tool unless I’m in quad retopo but you can also use the standard loop tool.
I’ll have to check when I’m at computer.
damaggio
yeah it wasn't Shift, You just need to hold "Control" key down with the Multi cut tool active or Shelf button Mesh Tools>Insert edge loop which has better modeling features.
