Line up verticies?
Line up verticies?
Message 1 of 10
Line up verticies?
Hi
I am in quad draw and would like to know if it is possible to line up a bunch of verts based on the first and last vert (see attached)
The only way I can see to do this is to draw a line with verts in similar places and then snap to vertex but that seems a long way around.
Replies (9)
Message 2 of 10
n8skow
You can turn off 'retain component spacing' in the 'move' options, select your verts you want to move - and then snap to the vert you want them to line up with.
Message 3 of 10
@n8skow
Unfortunately there are no snapping options with quad draw.
thanks for the reply (kudo given reply accepted)
Message 4 of 10
n8skow
Quad draw is not a tool I'm very familiar with yet - but can't you go to component view (F8) and move your verts?
Message 5 of 10
Hey @n8skow
please see screencast
Message 6 of 10
n8skow
I see... I'm sorry I'm not any help in this area.
Mspeer's suggestion seems to be fairly easy though?
Do your verts stay constrained to the same plane?
Message 7 of 10
@n8skow
Thank you. Yes they are on the same plane.
maybe there is a Mel script available that lines up vents between the first and last vert
Message 8 of 10
mspeer
Hi!
You can use helper objects for constraints / snapping, like a curve or a Polygon,or if they are already planar, just move the inner vertices far outside and then use Multi-Cut.
There is no script that does this, but you could create one on your own.
Message 9 of 10
@mspeer
thanks.
As you can see from my other thread the answer for me is snap to curve using the bezier as the guide. Multicut would change my topolgy as I am learning to poly model and creating the topology is my main learning aim at the moment.
I am only a few weeks into Maya so creating a Mel Script is not on my skill list at present
These forums have been a great help thank you
Message 10 of 10
@mspeer @n8skow
Thank you for the help - answer is in the screencast just to tie up this thread
