Layout UV's to fit model position.
Hello i have a laptop keys that are without textures and im searching for a quickest way to texture them.
As you can see, every key got the same square uvs is there a way to select them all and layout the uvs so the uvs keep the "keyboard" shape and position? So i can then apply the keyboard texture and don't bother with a single key at the time?
I hope it all make sense.
texture
Thanks in advance
mspeer
Hi!
Modeling menu:
UV -> Planar
UV Editor menu:
Create -> Planar
Select Y axis for projection.
Much thanks!
