Issue with mesh "inputs"!!
Hello all, I'm a very beginner, I do have some problem, when I create for example a mash cube I can't see the inputs in the channel box, it means I can not adjust, width, height, depth and the subdivisions!
My issue is not related to the mash history.
mspeer
Hi!
It is for sure a problem with history.
Make sure history is enabled "before" you create the cube.
If this does not help, try a reset of your preferences.
Rename the folder prefs in folder 2020 to something like prefs_backup, or to reset everything, the folder 2020 to 2020_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
Hello, thank you very much first of all;
you right the problem was that, now I do have another silly problem I would like to know which is the feature neme, usually the other software, when you go above the feature botton they show which is the feature's name, is it that possible also in maya (maybe are called pop ups or something?).
Thank you very much again!!
mspeer
Hi!
Preferences -> Help -> Popup Help
or check the bottom of the Maya UI for the content in Help Line.
Thax mate....but I don't find the menu preferences... thats weird!
mspeer
Hi!
Just check the Maya online help.
In Maya main menu:
Windows -> Settings/Preferences -> Preferences
Top! thank you very much, sorry I'm just very used to other kind of software!
