Announcements
Importing FBX with textures
stony331
stony331
Hello Mayan jedi's, my biggest struggle is importing a FBX w textures linked, I bought this porsche from a site and when I import the fbx the textures are not linked, just getting a grey model.  I just want to see if it's something I'm doing wrong or I have to manually assign the textures.  I attached the file, thanks.
hamsterHamster
The FBX is made with UN-embedded media, and that might be the reason why the textures aren't linked to the shaders. FBX shaders as well aren't that elaborated, and you will look for the do-over which suits render engine (Arnold, Vray, PRman to name some) of your choice best. The texture and shader naming is a hint for linking - if you want simplistic model preview, import all the _albedo textures and link to each shader's Diffuse swatch.
The supplied texture set is sufficient to achieve physics based rendering (PBR)- roughness, ao, metallic and normal maps are good starting point.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
stony331
Thank you for taking the time the answer my question, I am using Vray and will use your advice.
