I can't use Multi Cut Tool nor Insert Edge Loop?
Hi. I was working on a jacket and I deleted some polygons on the bottom to make the jacket shorter. Then I extruded the edges twice and I wanted an edge, to create a crease. But the multi cut tool does not react with this object anymore. Neither does the Insert Edge Loop.
I have to say, before this, the object was an nCloth but I deleted the history and deleted the nCloth, so it should be working fine as a normal object again. Please help?
PS: I don't know how to link an actual Maya file, in case someone wants to take a look, can someone tell me how to do this?
sarahagberg
Would love a reply to this too!
damaggio
the object is not quads.
sarahagberg
Thank you for the answer! I'm totally new to 3D modelling and I'm just getting myself acquainted to the syntax. I figured out that I could use Quad Draw based on your answer. But is there any way  of "resetting" the model to standard? To make it "quads"?
mihirsbcc
Select the object and from Mesh Menu First run REMESH tool default, then RETOPO  option and choose KEEP HARD EDGE. That should convert your triangle geo to quad. If the model is game ready downloaded polygon, Some of them do not work.
mihirsbcc
you have to upload to google drive and use the link to share.
