How to measure size accurately in MM for objects.
videogames2theend
Message 1 of 8
videogames2theend
Hello I am using maya for making 3d designs to 3d print and was wondering how I could accurately measure the size of an object in MM units. I know how to change my working units to MM but those dont seem to change anything.
Replies (7)
Message 2 of 8
hamsterHamster
See Create>MeasureTools>
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
Message 3 of 8
videogames2theend
is that measuring in MM?
Message 4 of 8
hamsterHamster
In whatever you want.. even angstroms, anyone? Why can't you try it yourself?
,,,_°(O__O)°_,,,
Message 5 of 8
videogames2theend
i dont know how to tell if its in MM as it does not say anything about units, and I have nothing to compare it do in maya that i know the exact scale of.
Message 6 of 8
hamsterHamster
Here, what are your Working Units? Default setting is CM, so the measurements are in centimeters. Not too hard to figure once you create default cube and measure its edge.
,,,_°(O__O)°_,,,
Message 7 of 8
im working in MM, i used the measure tool and its saying an object is 123.697 tall but when i export it prusa slicer to comes out to being 12.44 MM.
Message 8 of 8
hamsterHamster
Sorry, I am not familiar to Slicer. Even assuming you measured precisely vertex-to-vertex, some precision discrepancies might happen on translation from one software to another. Keep in mind, Maya primarily is a tool for animation, where that minute relation to the real life is kind of irrelevant. For the precision you'd look in AutoCad or Inventor then.
As for the printing, the Slicer would be the final say about the object's size, since it is directly related to the printing hardware. Therefore I'd model in Maya, and scale up imported model within Slicer so that it fits desired dimensions.
,,,_°(O__O)°_,,,
