Announcements
How to do this with ncloth?
GGPS90
GGPS90
I want to deform those planes onto the shirt so that i can apply an image. Can i do it with ncloth? Can anyone tell me how to do this, just a quick rundown?
damaggio
UV map the shirt and apply a texture instead.
you can also use the quad draw tool , however if the shirt is gonna be re-simed or
Animated the first option is the best one.
GGPS90
I need the planes to be separate and be a specific dimension as it will be used on web and textures will be loaded dynamically. My usual way of doing it is shrinkwrap deformer but, sometimes the shirt have a lot of creases and im wondering if ncloth is easier.
hamsterHamster
nCloth definitely isn't easier.
I'd try shrinkwrapping to body mesh instead, with some offset; delete History.. If you want the patch assuming some of shirt's features, then setting shirt Live, you can snap all/part of vertices to it.
Also, possible to use blendshapes to blend between the body-wrapped and shirt-snapped versions
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
