How to connect these edges?
I want to connect those two selected edges to form a whole mesh. How do I do this? I tried bridge and there was no effect at all.
mspeer
Hi!
Try Append to Polygon tool.
Sort of worked, but really didn't. I could connect one part to another, but only by selecting one small edge from one loop and one small edge from the other loop, connecting them and then using bridge on the rest. It didn't connect both edge loops automatically in one click.
mspeer
Hi!
Sure, this is how this tool works. You need to select all edges individually you want to be connected.
damaggio
Another option is to delete the center/ fill hole tool/  than use circularize tool.+ extrude.
amaterasu-qbb
First, you need to check vertex number,
Go to Display>Head Up Display>Poly Count and select edges.
Same vertexs number are easy and clean when you connect object to other.
both object seems to me not same number of vertex.
So i will make new cylinder as 24 vertex. snap it to original and delete original.
And check vertex y position from Component editor(Window>General editor>Component editor)
make sure vertex are same height.
and extrude both edges(If you do this the shape of model still original)
and merge!(I did with target weld)
Difference number of vertexDifference number of vertex1-11-1Component editorComponent editorselect 1, select2select 1, select2DoneDone
