How do I mirror objects to the top ?
The_Viruss
Message 1 of 8
The_Viruss
Hey all,
I have a question? And indeed I would like to copy the top so mirror. What is the best way to do this? From left to right I have managed via -1 but now I'm trying to copy from all 4 sides exactly that to the top without moving it. I have the bottom two on the other side also so would have to be copied on both sides again to the top.
Replies (7)
Message 2 of 8
damaggio
You can group them and mirror -Y, set the correct pivot point.... you can also combine the pieces and then -Y...freeze the transforms off course.
Message 3 of 8
The_Viruss
Thank you has worked 😉
Message 4 of 8
damaggio
Remember that the Uvs have to be flipped after that.
Message 5 of 8
The_Viruss
With the Uv I have done nothing at all ;D but I have the program RizomUV there I will do it then. In Maya it all looks just so.
Message 6 of 8
damaggio
Yeah that’s fine, you can UV at the end.
Message 7 of 8
The_Viruss
Another question. Why has the size of the object changed when mirroring oO If I put it on one side on the other it does not fit on the other side again ;D
Message 8 of 8
damaggio
I'm sorry, I can't tell what this image is, also mirroring cannot have a value of Zero.
