Announcements
How do I make my reference image transparent?
Samsam2019
Samsam2019
Hello all,
I am trying to make my image reference transparent (or lower the opacity like Photoshop) but I am not sure on how to do this. Can someone please tell me? Thank you
oscarrmichell
If you select your image plane and open the attribute editor you should be on the "Shape tab" for the image plane. near the top, you should see a slider with the name: Alpha Gain. This will adjust the opacity of the image plane. Hope this helps.
Samsam2019
Thank you! 😄
Hans_Redman
Just use the material called 'Phong', you can change transparency in 'Common Material Properties'. Easy and quick.
