How can I make the image Backface Culling in maya
How can I make the image in maya look through one side like in 3ds max backface cull. So when you rotate one side the image is not blocking your view.
trs_andre
Hi!
Do you mean something like selecting the object, going to the Attribute Editor, and under Render Stats unchecking the "Double Sided" option?
André Moreira
Game Developer / Technical Artist
LinkedIn
Thanks for the reply but in maya 2020 under the render stats don'thave a check or un-check button.
stuzzz
hi,
You might be able to see this attribute in the shape node.
you can also select your geometry then Display-> Polygons-> Backface Culling.
BTW I'm not sure to know what you mean by "image", is that texture?
image is the picture you load in the viewports to model.
mspeer
Hi!
This is not possible with image planes.
Use polygon or nurbs planes instead.
