Help with warning!!
Help with warning!!
Help with warning!!
Hello Maya community,
I am having problems with a warning coming up when I try and export via .FBX. It comes up with this warning:
[WARNING] Unsupported map(s). - The plug-in does not support the following maps and will not export them.
To learn how to convert them so they export correctly, see Edit > Convert to File Texture in the Maya documentation. checker1
I have cleared one checker pattern from the model but I can't find this one. I have taken apart the whole house and still have not found it. My question is, is there a way I can search for textures to locate where it is faster or some other way I can find out where this is? Any help will be appreciated. I am not an expert by any means I actually started using Maya this month. I am just practicing my skills and having fun. 🙂 Thanks in advance for any help you all can be.
mspeer
Hi!
Outliner -> Display -> DAG Object Only (uncheck)
Enter "checker" in Search field.
or
Hypershade -> Textures
Enter "checker*" in Search field and hit Enter (yes, this search field is different than the one in Outliner and has some bugs).
Thanks so much! Saved me a lot of time and frustration.
