Help with intersecting a tube into a wall
broneeandreas
Message 1 of 14
broneeandreas
Hi guys.
I want to create a tunnel going from a poly-plane without booleaning. I tried 8 times with different ways but they always end op being a topology mess. What is the best way to achieve this, I posted a screenshot to further explain what I am trying to.
Replies (13)
Message 2 of 14
damaggio
You could start with a cilynder and a cube , booleans could be used here too and a bit of cleaning up, tunnels like these are always fun, specially texturing and lighting.
Message 3 of 14
broneeandreas
Ty for the answer. I tried this, but it wont let me bevel the edge, it says it has an non-manifold vertex. I posted a picture of the mesh.
Message 4 of 14
damaggio
it is not marked where you want to bevel.
You should not have that poly plane down below, you can delete that and have the floor be a separate piece.
Models are not made from a single piece, is just like real life construction .
Message 5 of 14
broneeandreas
So, so should I great a new polygon cube and merge its vertix, or simply let it float?
Message 6 of 14
damaggio
Here's a simple example, all could be made out of the cylinder, no booleans needed anytime soon, from the cylinder corners you can extrude other walls or simply have them modeled separately, the cylinder can be bent with a deformer.
The floor is a separate piece, can also be bent .
Message 7 of 14
broneeandreas
Not sure if I understand, but I already tried with the method of just going with the cylinder, but when I extrude the outside faces, I am left with a hole from the faces inside the cylinder.
Message 8 of 14
broneeandreas
Ah, I think I get it now, I just made a quick one from your idea, however, do i maintain the inside of the cylinder when extruding the faces outwards?
Message 9 of 14
damaggio
You created more problems now because you lost the inner circle walls...here's another way of doing it...
Message 10 of 14
broneeandreas
I see, but how would you integrate the floors then?
Message 11 of 14
broneeandreas
When I flatten the bottom, it ends up like this.
Message 12 of 14
damaggio
You have to use a another cylinder as a reference so you maintain the right curvature.
Place another cylinder on top and match by looking thru orthographic.
Message 13 of 14
broneeandreas
Placing the cylinder so it matches the hole exactly, and then adjusting the vertex?
Message 14 of 14
damaggio
Yes, you got it.
