Help with Curves
Help with Curves
Help with Curves
Can you help a noob out, please? I have struggled to make a block with an edge curve as a polygon, as I was not able to get the correct shape, so I switched over to curves with the intention of converting them into a polygon. So I created a curve, duplicated it and lofted them, duplicated it 4 times and made them into a square. However now I need to join the ends and lose the excess that is sticking out past the desired shape.  (I have attached an image of a corner to show the issue.)
Any help greatly appreciated!
trs_andre
Hi!
You might try using Mesh→Booleans→Intersection option!
If you get some out of place vertices, Edit Mesh→Merge should do the trick!
Hope it helps!
André Moreira
Game Developer / Technical Artist
LinkedIn
Brilliant, thanks, but just to clarify, it is not the Mesh option, but the surface option and it is not the one inside the Booleans group, but the one in the root of Surfaces., but it worked like a dream, thanks.
trs_andre
Yes! Sorry, it was a surface. My bad 😅
Glad to help!
André Moreira
LinkedIn
