Help importing stl files
Hi im importing a file from shapeways that is in a stl file. I work in MM in maya, when importing the stl file is is way blown up, i think to inches? is there a way to get the stl file to import to MM? i am haveing trouble figuring this out, there is no so such option when clicking import to set it to MM and im a bit lost and need to fix this file. any help would be appreciated.
As you can see in the photo the smaller ones are my working files and in import is the stl file blown up to (inches?)
Just giving a last bumb before i check up on this post, I still cant find a solution to my problem and am loosing faith. Im hoping someone who had this problem will see this and have a solution.
