Grouping
Grouping
angelailling_tg
Grouping
angelailling_tg
Community Visitor
Community Visitor
Hi I have created a group. They will only move as one if I select the group in the Outliner. If I select the whole spine in the viewport, it only selects one mesh. Please assist. Thank you
Christoph_Schaedl
Use the up arrow key on your keyboard to select the group.
https://linktr.ee/cg_oglu
michael.easter
This is normal behavior. Selecting in viewport will normally select the lowest object in a hierarchy. If you want to select by the highest you can turn on "Select By Hierarchy And Combinations"
More info can be found here:
Maya Help | Select objects based on hierarchy | Autodesk
illingCN5FB
Community Visitor
Community Visitor
Thank you so much.
illingCN5FB
Community Visitor
Community Visitor
Thank you so much.
